How do I scan this accurately(mini2 on PC) ? I have tried a “million” times. Originally black, but after having used scanning spray too many times I just gave up and spray painted white
it has become a bit of an obsession to get this right
for some reason it is impossible for the scanner to see any features and I always end up with shifts. I think I have tried all tricks I have found except adding features to the object itself. I really don’t understand what is considered “features” by revoscan.
It is quite thin, 5mm at the thickest and I am trying to get a full scan. Scanning flat with markers works, but aligning both sides is a bit hit and miss (using cloud compare). Scanning standing up, on short/long side mostly end up in tracking loss, despite adding items such as small tracking cubes. I am considering 3d printing a tracking tower to see if that helps. I have tried adding paper, bits and pieces of varying height next to the object etc. with only marginal success.
I cannot understand why the scanner is incapable in seeing any “features”.
Too be honest I am quite disappointed in the mini 2 scanner so far, unless you are scanning trivial objects it seems to be quite finicky and temperamental, as well as sensitive to lighting conditions and object shininess/color/color-contrast. So far my attempts with photogrammetry and Reality Capture has proven to be far more successful. Is it just me that is having this user experience? I would have thought that the software would be quite a bit more advanced at this stage especially with regard to object tracking.
Geir
