Yesterday I wanted to use my meta quest VR cable but the miraco only connected to the PC for a short time and the battery indicator just flashed and kept making acoustic beeping noises… is the cable too long? 5m
Most likely the cable is to long.
You should use the included cable or a cable under 3ft.
OK thanks… Power lost
You should not use your PC to power your MIRACO for a very long time , charge it proper before use , or use powered USB HUB .
Don’t waste your USB port as over time it will suffer .
I use 6 ft cable without issues but connected the powered USB HUB
Yes ok… thank you for your answer
