USB issue with Metro Y Pro and 2025 Asus G16 Laptop
I was not able to get high speeds cans on my 2025 Asus G16 with i9 and 5070 ti. It seems to always think it was USB 2.0 cable but with Rasor TB 5 dock connected to its TB 4 / USB 4 port it connected by had low speeds. Same configuration connected directly to USB C port on my Alienware R16 with i9 and 4080 super work find.
I was able to get full speeds on Asus with wifi connection and got 58 fps - but could not get Metro Mirror to work. It was looking for ip address and ipconfig address of laptop did not work.
I have only 2 ports that works proper and that are Thunderbolt 4 USB C on my laptop , any other USB A 3.2 port do not response at all , I saw in the other thread that people update the USB chipset manually and make it works just fine .
I am sure it is related the the USB port because it works even fine on my Win11 i7 tablet.
I was too busy testing out my MetroY & Pro scanners and INSPIRE 2 and had no time yet to try the mirror app at all .
I believe my Asus is asking for update. So you think this is Bios issue or software issue.
Is there a quick way to remove a plane - I saw that done in a review.
Stewart
PS I would like to get this working, and it good for another sale. My sister’s husband has a company that make parts forf abulances and Metro Y pro would fit perfectly in the company. They used soldworks and doing millions of dollars of business
I actually didn’t have time to try Revo mirror but I think the manual on the site says you can connect your phone to the WiFi hotspot the metro Y creates and than it should show up in the revo mirror app. Only thing to consider is that your phone might disconnect wifi because there’s no internet
II have yet to try it with out - with mirror
There is settings in the phone to stop disconnecting the scanner WiFi network because of the lack of Internet .
I having this happen on my Alienware R16 when connecting on wifi - but on Asus G16, if I switch modes to full, Revo Metro crashes. I will try to updated my Asus
I did an update on bios of the my Asus G16 and it appear to work ok and was getting 58 fps
58 fps is excellent and optimal speed .. glad to hear you resolved the issue .
This forum is better than support
It seems your Asus G16 is misidentifying the Thunderbolt connection, limiting speeds, while your Alienware R16 works fine. For Metro Mirror, ensure the correct IP address is set by manually assigning it or checking network settings.
It does not matter for me, because of other issues with Metro Y Pro, I ended it returning it.
