Hi,
My Revopoint3D works fine, however the USB 3.0 cable is not long enough. I have bought a USB 3.0 extension and it does not detect the Scanner, then I have bought an amplified USB 3.0 cable
https://www.amazon.es/gp/product/B073J92722/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 and it doesn’t work either. Is this cable not correct? What should I do to have more cable length with my Desktop?
Hey Cassie, any ideas? Thx!
I use an extension. A lot of the time they can be hit an miss. Usually the best ones are the heavy duty cables which drop less voltage/current over the length. 5 metres is a bit long to be fair, data will have no probs but you’ll loose voltage at only 5V with that length.
I took a look at an English version of a similar product. It draws its power from the USB port at the other end of the 5 meter cable, so the current drain could cause too much of a voltage drop for the amplifier to work.
It is also possible that the USB port providing the power isn’t suitable for this application. Have you verified performance with a shorter cable?
Also, unless you need Marker mode, you’d probably be better off using a Hotspot because a 5 meter cable is going to get stepped on and kinked, damaging its long-term viability.
The POP 2 can use 5GHz Hotspots; I don’t know if Marker mode will be allowed for that higher-speed connection.
The explanation from @JonHimself is correct. I discussed this with our engineer. They think this cable you bought has LED and other features which drop the voltage/current. If you need an extension, you should choose a simple one (like below) that doesn’t have many additional features.
Cassie
Hi Cassie and friends.
A cable similar to the one you suggest is the first one I tried, 3 m. That I bought and connects intermittently.
I think I have found a possible solution for the voltage drop:
" I connect a 3m USB 3.0 cable. from the Desktop to a USB 3.0 Hub with external power and then I connect the scanner to the Hub with its original cable and at the moment the connection between the scanner and the desktop is not lost."
