All my attempts to rename a RevoTrack project are failing. Will RevoTrack handle just renaming the project file via windows? I seem to remember that breaking things in the past.
Renaming project via the Homepage will not rename the actual project saved by on the hard drive .
The homepage is not a browser , it is preview of the last opened project .
Change the name of your project direct on the location . Only the project folder name and never inside structure.
- Open Folder
- Change the project folder name
- Open the project folder you changed the name in Revo Scan again to add it to the homepage history
This worked in RevoScan just as I’m showing it. I could rename from the home page as shown, and the project file in windows would assume the new name.
So I just did this:
- Start a new project and use the “project naming popup” to change the default name at the time of creation (TSC_ShortARM).
- Save the project (without scanning).
- Exit to the home page to see if the project name was created correctly.
When I go to the home page the newly created project doesn’t show up. It DID however create that project in the specified project directory with the correct/selected name.
What I see on the home page (at step3):
What I see in windows (at step3)
The data folder inside of the new project is empty, but the file “TSC_ShortARM.revo” was created / exists. I can open the .revo file directly as expected. (clicking in windows, not from RevoTrack)
If I import data to the project (after opening with windows), then it shows up on the homepage. AFTER THAT I can rename the project from the homepage as expected.
So, basically if I don’t select a specific name for a project during creation, it can’t be renamed from the homepage. This appears to be a regression from Revoscan.
It also appears that if a project is created, saved without data, it can’t be displayed on the home page. It’s almost like if there is no “preview” the project can’t exist on the homepage.
I guessI was not clear , did you checked the project in the actual folder after changing its name on the Homepage ?
I always give a band if needed before starting a new project anyway and never after .
For a reason that the main folders did not changed its name via homepage , unless this bug was fixed already .
