Trim before fusion or to rescan a certain area
Hey!
Is it me or there isn’t an option to delete a certain part of scan for example with lasso so i can rescan a certain area of scan that i think did not scan well.
Or just to trim unneccessary stuff before going into fusion.
Is this possible?
Those tools on the right side of revoscan cant be clicked on…
Hi @niklavs91 , you can click into key frames edit for this.|
You can trim everything , before fusing , after fusing after meshing , all options are available on the right side of the screen …
I would recommend to trim the scan before fusing in raw mode , it will give you better fusing results .
Also if you going for merging , I would recommend to use Advanced fusing option for better edge results and less cleaning .
