Hey there, I’m using the new Revoscan 5.1 and am scanning an action figure. The details are great! I do have one question though. How can I eliminate the “noise” between the legs and body/arms? Or can I? Just looking for some options to try other than putting the file in Blender or another tool and removing it.
Hi @IndyColtsFan you need to clean the legs and arms area before you mesh the point cloud , best after fusing ,you can use the tool on the right side of the software screen , select what you want to go and click the bean icon to remove
Please use Advanced mode if you don’t want to clean too much manually … other way you have to clean lose points
Thanks! What is the tool or menu selection called that I would use?
You can use any of them , depends of what you need , but in your case the lasso would be the best, it is on the right side of the app starting from top
As usual, you rock. Thanks!
