am i missing something? I am just going to file → open
i just installed 2.14.alpha and it gives me the same issue…
Could you maybe share a video of you importing the file to CC, as that’s very weird?
Your .ply file doesn’t seem to be corrupted in any way ![]()
What is actually the purpose why you want to have the pointcloud /mesh in cloudcompare?
I’ve looked for that and found this thread:
Still I am not sure if and how this might be related to your problem…
Did you made any adjusting on the import panel ? Because that’s what it looks like .
We all tried and there is no error so it must be on your side
Reset the software settings and if not working , remove the original software and all related folders , the wrong settings that got stored may be affecting the import .
To test it out , import any other 3D model and check the points amount.
how do I reset the settings? I can’t seem to find that online other than resetting the gui elements
I ended up trying this on Meshmixer and it worked perfectly-no issues. All I need to do was be able to open the scan and level it and mesh mixer got the job done easily. I am not sure if I have an install issue with CloudCompare?
i just go to open - select the file and that’s it. I would post a video but it won’t show much! For my scans I need to specify the front, back, etc and make them true orthogonal views and that’s why I am using CloudCompare. i am basically making the scans level
that did it! I reset the “vbo’s” and it is working perfectly now! Thanks a lot for your help. This is exactly what I need it to do
Happy to hear it worked for you!
I am still surprised it kept the settings even after new installation , it must be stored somewhere under User/AppData
Anyway we learning new things everyday ! Part of the never ending learning process .
