I scanned my sneaker in several passes. Cleaned them all up, merged them together, meshed it, and closed a few holes. The vertex colors are there but the Texture button is greyed out. Is that normal?
Revo Metro 5.8.3
Revo Metro 5.8.3
Hi Phil ,
How you doing ? Long time no see
What scanner are you using ?
I assume all color projects are in the same main project ?
Yes, I missed you at Printopia. Oh I forgot to say it. My messages disappeared and I had to type it all over again. The Inspire 2. Yes it’s all in the same project.
OK I solved the problem, it was my fault. After I made the mesh I deleted the scans to save memory. Turns out those are needed for the texture information. I did the scan again and kept them. This time I had the Texture button.
Hi Phil , I suspected you removed the image data , for that reason I asked if the projects are still available and not just point clouds .
I wish there was a way to create the textures direct from just from vertex color but right now it is impossible.
