This was a super fast 3D scan using POP3D scanner, Realme X2 Pro Smartphone and 10K mAh powerbank (5v 2a) to power up the scanner, the whole scanning process didn’t take more than 10 minutes (including processing, fusing and meshing), 3d scanning has never been easier!
Hi @XYZee_Maker
Thank you very much for sharing this great result here!
@XYZee_Maker that looks great!
Did you do the scan on your own (“Selfie” mode) or did someone else move the scanner while you sat still?
