Suggestion: sandalone cable
Would be good if there was optional cable available to connect just a scanner on its own and a power brick to a pc without tracker. Getting all thag nest of cables and a tracker out just to scan little part on the turntable in target mode is a pain.
Hi @Snoopdoor
It is right now impossible to do that as that scanner would not work without the tracker at all .
You can power it up with a power bank but it will be never recognized by the software without the tracker being connected to the main software .
Please don’t try any of it as you can violate the scanner warranty if anything get wrong .
I wish it could be your way but it is sadly designed this way .
Ok got it. It works very well just with a few markers no point setting it all up everytime for me. Hopefully there could be a solution made for it to work.
I understand you very well , I wish it could works as standalone in regular market mode but the design prevent it sadly.
I will forward your suggestions to the team
