[Winner Announced]Trackit FAQ Giveaway! 🎁
Thank you all for your enthusiastic participation!
Congratulations to Yuriy Melnik, @WiczDesigns, Teerawat Krub, Skid Mark, 414clint for winning the Prize!
Winners, please email us at socialmedia@revopoint3d.com within 3 working days to claim your prizes!
Stay tuned for more exciting activities coming soon!
You’ve seen Trackit in action, but do you still have questions? Ask now for a chance to win a Revopoint USB drive and sticker pack!
:speech_balloon: How to Enter:
Share any questions you have about Trackit below!
We’ll reply to your questions in the comments!
:tada: We will randomly select 5 winners to get a special gift:
Revopoint USB drive + sticker pack!
:spiral_calendar: Deadline: July 14
:white_check_mark: Giveaway will be activated if we receive 10 or more comments — so jump in and ask away!
Let’s clear up those last questions!
T&Cs: Terms and Conditions of All Revopoint Contests - Contests - Revopoint 3D
Edit: I found some answers in the kickstarter FAQ so I have updated my post with new questions/answers.
Question 1:
What is the wattage of the entire system? Primarily the tracker which requires a power supply connection. I am wondering what kind of portable battery chargers would power the system + a laptop
Question 2:
When do I need to calibrate? Everytime I take the scanner out of the box? What about multi-position scanning when I need to move the tracker around a car? What if I have the tracker set up in a studio and turn it off? Do I need to calibrate every time?
Question 4:
Why can I NOT use the scanner outside?
Question 5 (answered)
Can you use the scanner independent of the tracker? While the tracker system is very impressive, it seems like a hassle to set up for smaller objects, especially since you mention that it takes 25 minutes to fully calibrate
Answer on kickstarter: You can use the scanner independently of the tracker with marker mode.
Question 6 (answered)
There are only blue laser modes on the scanner correct? This would mean that this scanner is great for inanimate objects, but not good for humans whose eyes can be damaged with the lasers
Answer on kickstarter: Class 1 lasers, avoid eyes.
Question 7 (answered)
What are the minimum and reccomended PC requirements to use this scanner?
Minimum PC Requirements
System Version: Windows 10/11 (64-bit)
RAM: ≥ 32 GB
CPU: Intel i7 13th Gen or better/AMD Ryzen 7 7000 series or better
GPU: NVIDIA GeForce RTX 3050 (8 GB)
Recommended PC Requirements
RAM: ≥ 64 GB
CPU: Intel i9 12th Gen or better
GPU: NVIDIA RTX 4060 (8 GB) or better
Note: The software is only compatible with x86_64 architecture. If you’re unsure about the CPU configuration, please ensure that the CPU has cores ≥ 8, threads ≥ 16, and a base frequency ≥2.4GHz. Please ensure the USB port on your PC is USB 3.0 or above.
Question 8 (answered) What is the length of the scanner cord that connects to the PC?
Answer on kickstarter: Trackit’s power cable is 4.5m, and the USB cables (Tracker to PC, scanner to Tracker) which use to scan are 6m, giving you enough length to move around the item being scanned freely.
Correction : it uses 2M class blue laser
Class 1 lasers are not really damaging to the eyes
Winners :trophy: Announcement
