After using Revoscan on the Android a bit more, I’ve stumbled across another bit of feedback:
Steps to reproduce this issue:
Using Revoscan 5.0.2, on Android
Using a Revopoint Mini
Start a new project, or continue scanning an existing project:
The Mini will sync, and spray your target object in blue laser light for the depth camera to capture.
Press “>” to Scan new frames
Press “||” to pause when done scanning
Press the “Stop” box to enter post processing
When the three checkmarks indicating the scan/fusing/meshing are completed:
The Mini is still lighitng the object with the blue laser during this step!
When you complete meshing, and either share, or go back to the “home” screen, the blue laser light cast on the object does stop.
My suggestion:
- Move the “turn off the laser light” step further up in this chain of steps – when we start post-processing
- There is no way the program can or will ask for further scans from the Mini, so it should be in a more idle state at this point.
- Turning off the cast laser light for the depth camera would allow the Mini to cool down sooner, and consume a little less power.
I’ll guess, since I don’t own a Pop or Pop2, they may also benefit from this. Your tech team and the programmers will know this better than me!
And, since I have not tested this on the other platforms, I don’t know if the scanner is left ready to scan during post-processing on the other platforms (iOS, Mac, Windows), or not.
Hope this helps out! If further specifics are needed, please ask and I will do my best to answer.
