Sometimes the scanner has a problem starting, even after confirming that the device is connected.
It’s my turn to disconnect and reconnect the power supply to the device.
I have already written about this behavior of the program (and it is present in both versions 5.6.4 and 5.6.5). So far, the only working way to get around this problem is to run the program before connecting the scanner.
Yes I came across this as well
As @OBN_RacerMan mentioned already
For now and always , start the software first , then connect the scanner after.
It works better for all Revopoint scanners this way.
