MetroX scanner disconnected after update Revo Scan 5.6.3 and FW
Hello, support team,
Today Revo scan software told to update software so I decided to select yes.
The window program upgraded and when the new software starts it said scanner firmware update as well so I also select to yes.
however, after then the Revo Scan could not connect to the scanner device at all.
What shall I do ?
Thanks in advance.
@bpark
Just restart it and try again if the message prompts.
Make sure you restart also the scanner before . First start the software then connect scanner .
after restart the system, the new software can be connected to the scanner.
Thanks!
