Skip the scanning spray and never struggle with reflective or dark surfaces again!
INSPIRE 2’s 11-line parallel infrared laser scanning, effortlessly capturing detailed, dark, or shiny surfaces.
Defeat the toughest surfaces. Pre-order now.
Use code MEDIAIN2FO2 for an extra 5% OFF!
US store: Revopoint MetroY Pro: Wireless Blue Laser 3D Scanner | Global store: Revopoint MetroY Pro: Wireless Blue Laser 3D Scanner
Yes please ! So many possibilities here , especially on the go ! I want it , I need it !
I cant lie I am considering it so i can just chuck it in my back pack to have it while on the go
Definitely a must have gadget in your backpack on the go ! I can’t recommend enough !
Hey, do you think it will pick up metal and super reflective objects just fine? Maybe like a knife blade? This would be my first scanner or should I go for the metrox? Thanks!
You can’t scan super reflective surfaces like polished metals or mirrors , the surface still need to project the infrared laser on it , so super reflective will mess up with the sensor no matter what scanner you are using .
As for starter , I suggest you get INSPIRE 2 , it is less problematic, easy to use and very portable . A good device to start your new journey plus you can scan other objects that other scanners could have issue with like living subjects . More versatile for beginners and more fun !
Thanks for the feedback, another question for you though. If I’m planning on scanning mostly metal even if it is dull metals do you think the inspire 2 will have about the same scanning ability to scan metals as the metrox? Thanks so much!
MetroX is faster and MetroY and MetroY Pro even double faster than MetroX
So if you have budged and only have interest in scanning metals and mechanic parts , invest better in MetroY , it is 3 times faster than INSPIRE 2 laser mode, 2 times faster than MetroX , and wireless and can scan everything you need.
