| Meet the next-gen INSPIRE 2 3D Scanner with improved accuracy, precision, and a larger FOV for better tracking and more efficient scanning. Easily switch between infrared structured light and 11-line parallel laser modes for greater versatility across applications.
Simple to use, reliable results. Watch the video, there’s so much more to see!
Use code MEDIAIN2FO2 for 5% off your pre-order.
Available now at our US and Global stores.
Looks quite promising indeed.
I’m a little bit intrigued by the filters for outdoor scanning: I assume they filter out unwanted light wavelengths to improve the signal to noise ratio, or something similar?
I remember you mentioned something recently regarding integrating Revoscan and RevoscanX. I bet that integration will come sooner than expected… (taken from the Inspire2 link, btw)
All the newest laser scanners use Revo Metro , Inspire 2 uses infrared laser that is the reason why it is under Revo Metro, the same with Trackit and the other new scanners.
We are closer to Revo Scan 6 as you see by the build number , hopefully it will finally unite both of them.
