Hi all !
First Full Body Scan with Miraco ![]()
it took approximatly 5min to scan, large mode, general, standard fusing at 0.3 and mesh to 6
i’ve played with brightness during the scan for black hair (max 3 on level was sufficient) impressive !
hope you like it !
That is really smooth scan!!
Hi Seb,
Thank you so much for your showcases! They’re so impressive!
Thanks my friend
@Seb is there any dry shampoo or something similar on the hair to help with the scan? The end result looks really nice.
Hi, nothing applied on it. Thanks
Thanks, nothing applied on the air ![]()
How long did it take to scan the car?
approximatly 10 minutes
Hi all, a new scan made with Miraco, i love it ! ![]()
Pre order MIRACO now on Revopoint official website: Revopoint MIRACO: Big and Small Object Standalone 3D Scanning
Hello everyone, here is a new scan done with the Miraco (All the scan process), of a statue of Esmeralda, dark in bronze, once again, the Miraco is doing wonderfully, without even having to use dark mode. I’ve just used Far mode, I love it!
If you haven’t yet given in, here is the link to get it: Revopoint MIRACO: Big and Small Object Standalone 3D Scanning
hope you like this scan ![]()
Everything comes together to complicate a scanner, black and shine, surprised that the Miraco does so well
without scanning spray, just used far/high and dark mode !
3D Model Viewer:
This is an other Scan with Miraco, an Octavia Engine car. i love it !
No scanning Spray, just far mode High/general.
You can also see the sketchfab 3d model:
I hope you like it ![]()
Hi @Seb, thanks for this beautiful scan of the plant! Do you remember how long did the scan took, and did you do anything special to get the details of the leaves? Also, how does the version with the RGB textures look?
Thank you
I think I didn’t spend more than 5 minutes scanning it, however I couldn’t show you the textures because I hadn’t activated it during this scan. Sorry. And didn’t do anything on the leaves.
Thank you @Seb for answering my questions! Based on your experience with the Miraco, how well do you think the plant scan would have turned out if textures had been activated during the scan?
Would you be willing to share that model either via sketchfab or by another method? If you are unable to share it, don’t worry, I completely understand.
You’re welcome;)
There will be no impact if I scan it with the texture enabled, unfortunately I did this on my vacation, I don’t have the plant. And another important point, when I did this scan, my Miraco was not able to do the texture correctly (beta device). I think you will be able to find renderings with texture on the forum made with stock devices.
omg, thats SOOOO detail for the engine bay and the bike, even without scanning spray :o
