Scanning burned people to make pressure garments
Hi,
I’m looking for a solution to take precise measures of human body areas for the production of custom made pressotherapy garments for burn people. I was thinking of a portable scan, as we have to go either to Hospitals or patient homes, and an easy to use system.
We need to be able to get from the scan image all the necessary measures: as lenght and circumference (in different plans of the body parts - arms, legs, hands, fingers, foots, torso, head, etc.).
Any idea about the best way and scanner to buy and if it will answer our needs? Is there anything else I should buy, besides the scanner?
Thanks in advance for your inputs and help.
Great use case! Go with Miraco!
Hi @Lsogalho
The best in this case would be Revopoint’s Range 2 or one of MIRACO series. Also the upcoming INSPIRE 2 would be a great choice.
If you get Range 2 or Inspire 2 you can use it with your phone to capture your needed data on the go and later process it on your computer for better quality details and resolution.
MIRACO series scanners are the best choice because it allows you to scan very fine details like hands/fingers or bigger body parts like Head/torso/full body , since it have Near and Far mode ( 2 scanners in one )
It is also all in one scanner and data can be also process on a laptop or computer if needed.
Please avoid any laser scanners or modes while capturing living subjects, also blue light scanners are no recommended .
I hope it helps !
