Is it possible to scan an entire person with the Pop 2? If so what tips for it do you have? Thanks!
Hi @Rob765
It is possible to do it , I would recommend to use turntable when you doing it , and use Body settings .
There are not much tips , a little practice is required and make sure you don’t over scan the same areas too much and of course the person need to stand still any movement can result in ghosting of the scan.
Start with the left or right side of the face , one rotation and move slowly half way down of the already captured area , moving down too much can result in losing tracking so make sure you keep at least 10% overlapping.
If the person have a very dark and shiny hair I would recommend to use slightly dry shampoo or dust it very slightly with baby or mineral powder just to kill the shine.
I would recommend Range series or MIRACO for full body scans as it can capture full body in 2 min using turntable and it is much faster and easier due to bigger frame size .
