I had two images. I still have one. I did try to rename this first file.
I can’t find the renamed file. It didn’t go through the usual process of saving to a specific file.
I had done extensive editing to the second image.
I Saved under the File icon. Then I used Fision again to see if it would improve my edited image.
This didn’t happen and it reverted back to the original in-edited version.
After searching for some time, Deleted original un-edited version by mistake.
To be honest the image I have, I’m unsure which it is . The first or second that I extensively edited?
the renamed files are only visible after you open the project , thr main project under your folder do not change its name , only under history on Homepage , so if you renamed the project it is on Home page under history list
what image you talking about ? do you mean scan ? the project have RAW files and if you editing the files the original get updated , you should export your edited model before you edit it again .
You mean Fusion … how Fusion can improve your scan ? it is point cloud generator , it don;t improve anything , it generate a new point cloud from Raw cell frames . Without point cloud there is no mesh, it is a base for everything , so make sure you fused it proper , cleaned it and after meshed , if the point cloud looks not right , the mesh will looks bad too .
I don’t know what you have , you should pay attention and export things between to save copies and do not delete anything in the project or change names in your project folders , only via the software , you can change only the main project name in the folder, but not the other files inside the folders or it will not load .
I’m have trouble connecting the scanner again.
The pc is show the scanner connected on its hotspot. Yet it not connecting to the app.
If I unplug the scanner, the address disappears. Connect it again, it reappears. So the scanning is connecting.
What about USB cable connection direct to PC ? If you use hotspot on PC, don’t connect USB to PC as power source . Try to connect to the software using only USB .
