#RevoTips 12Why your black objects aren’t scanning?
Are you seeing a blank screen every time you try to scan a black object? Or perhaps your frame rate drops so low that the process feels impossible? You might think it is a hardware limit, but the solution is actually hidden in your settings.
In revotips 12, we reveal the exact adjustments needed to turn a failed scan into a high speed masterpiece. We are covering the one toggle that changes everything for dark textures and the simple tracking habit that eliminates lag instantly.
Swipe through to see the side by side comparisons and fix your workflow.
