Hi there, got the new revo scan update , it’s loading onto my iPad now which is good, but revoscan is only exporting in PLY, which I can’t use. How do I export to obj or stl, I see no options in the new software.
Thanks
Hi, you need to mesh the scan first, then you will see the options to export as stl/obj, as seen on the attached cap:
Revoscan for IPad doesn’t have this option …
You need to import it to a PC/Mac first
Thanks
Hopefully revopoint can fix this issue, for the people who don’t have/use computers … @Revopoint3d-Selina
There is no option to export model as obj at this moment since only ply is generated in the project files .
For now you will need to convert the ply to obj manually.
If you don’t use any computer , your scans will be only half as good ? Mobile apps are ok for scanning but the models they process have only half of the quality compared to what you get on computer .
P.S Selina is no more working for Revopoint .
Thanks for the info
