First of all, thank you for your help. I’ve found several solutions here for other issues, but this time, I’m experiencing something new and haven’t found the answer yet.
Today, I scanned a sofa using the Miraco Plus with the following configuration: Point Clouds, High Accuracy, Marker Alignment, and Far Mode. The file is quite large, around 2GB with 5251 frames. In raw mode, the preview is perfect, and the point cloud preview works very well. However, as soon as I run the fusion process (both on the Miraco and the PC version of the software), the model explodes, leaving me with an unrecognizable preview under the “fused” tab.
Does anyone have suggestions on how to fix this issue?
I am suspecting your project got corrupted , as I saw it before , the corruption don’t allow you to proper fuse the project and from what I know , there is no way to fix that .
The amount of frames you used is very high , something got wrong while capturing it .
The fact that you can see the raw representation of the files in your project do not change the fact that fusion function can’t proper read that project .
The project files are very sensitive so one wrong frame could prevent the fusion .
It never happened to me before but I saw it by other use not long time ago .
If you want to try , you can contact customer@revopoint3d.com and send them the zipped project files and include this thread link as referenced .
No you have and yes you may get
Another thing you can check is by opening the raw project editor and see in what condition the frames are under the raw editor , if it looks disturbed there is no chance to fix it .
That’s all I can do here for you in the forum regarding this issue .
