Revoscan 6 Shortcomiings
Subject: Revo Scan 6 — Multiple Bugs (Miraco Pro): Installer, Transfer, and 3D Mouse Issues
Hey folks, anyone else having these issues with Revoscan 6 and Miraco Pro?
This is an email I sent to customer support
I’m writing to report several significant issues I’ve encountered with Revo Scan 6 (build dated 7/25/26) on Windows, used with my Miraco Pro. Revo Scan 5 works correctly for all of the same tasks, so these appear to be regressions specific to version 6.
  1. Installer did not create shortcuts
    After installing, no shortcut was created in the Start Menu or Startup folder. I had to manually right-click the RevoScan6.exe and create one myself.
  2. Application requires “Run as administrator” to open at all
    Revo Scan 6 will not launch under my normal user account — the process starts and appears briefly in Task Manager, then closes with no window ever appearing. It only opens successfully when run elevated (as administrator). This suggests a permissions issue with the install, likely related to the installer not creating shortcuts properly either.
  3. Wi-Fi transfer never succeeds
    Wi-Fi transfers from the Miraco Pro consistently fail at a100% with “Model failed to transfer,” even though the Miraco shows a successful transfer on its end. I confirmed Revo Scan 6 was correctly added to Windows Defender Firewall with BOTH “Private” and “Public” access enabled (the initial first-run prompt had only requested Public access, which I corrected), but the transfer still fails every time regardless. I have not found any configuration that makes Wi-Fi transfer work in Revo Scan 6.
  4. USB transfer failed with “Model load failed” until a specific cable/port/setting combination was used
    USB transfers also initially reached 100% and then failed with “Model load failed. Import failed. Check the file and disk space, then retry.” This occurred with a USB-C to USB-A cable. It was only resolved after switching to the included USB-C to USB-C cable, plugging into a USB 3.0 port, and switching hardware acceleration to GPU mode. This should not require this level of trial and error for a basic file transfer, and Wi-Fi transfer remains completely broken regardless.
  5. 3Dconnexion SpaceMouse Enterprise does not work correctly in Revo Scan 6
    My 3D mouse works perfectly in Revo Scan 5 but only partially functions in Revo Scan 6 — zoom works, but pan/rotate and other functions do not. I found other users reporting this identical issue in your forum thread for the V6.0.0 release, so this appears to be a known, unresolved bug affecting multiple users.
Given the number and severity of these issues on a fresh install of a current release, I’d appreciate:
  • Confirmation of whether these are known bugs and being addressed
  • An estimated timeline for a patch, particularly for Wi-Fi transfer and the SpaceMouse issue
  • Any guidance on the installer/permissions issue, since requiring administrator privileges just to open the software is not normal behavior
I’m happy to provide log files, screenshots, or further details on request. For now, I’ve reverted to Revo Scan 5, which works reliably for all of the above.
Thank you,
Stu
Hi Stu ,
Thank you for your feedback, the technicians will review your report on Monday .
I can confirm the 3d mouse still not working in the latest release. I am waiting for months now to get this fixed…
Hi @Zappa
Please send your personal feedback to customer@revopoint3d.com
Hi im using pop4, i having the same issue, only run as administrator can open the software, else the process starts and appears briefly in Task Manager, then closes with no window ever appearing
Hi, i have the same problem, i’ve made a tiket on 3d connexion and they know this trouble, Revopoint also, but nothing change !!!
The 3D mouse was planned to be fixed this with new release I will check out with the team on it and let you know.
Also please send your feedback in person at customer@revopoint3d.com
@sbeef @wkit0807 again it will help me out supporting the case
I also have to confirm that the 3D mouse connection is no longer supported in RevoScan 6. It also annoys me that the retouching tool was removed.
I’ve already done that – I reported this issue with the Space Mouse as soon as version 6.3 was released.
Thanks , that is a good thing that you did ! It was promised to be ready this month so finger crossed.
We hope this will be fixed, along with the other bugs described at the start of this post
I think there are a lot of issues with version 6.3. Here’s a scan I did in version 6.2 – the merging was perfect, nothing needed touching up – but the point cloud processed with 6.3 after I’d installed it!!!
Hi, i’ve tested the new release 6.3.1 !!! space mouse don’t work !!!
Hi @sbeef
I will check with the team and find out .
Hi @sbeef
I am still waiting for the info regarding the space mouse…
Hi @sbeef
The team informed me that the Space Mouse integration is planned for the Revo Scan September’s release .
Thanks for your reply.
