Hi, I was wondering if anyone knows anything about video capture using the Range. Normally Microsoft kinect is used, or Azure. But the Revopoint Range has similar hardware does it not?
Hi @lolo2k
No it is not the same hardware and you can’t capture video with it .
It is Structured light scanner by projecting infrared pattern on an a steady object , the pattern distortions is then read by the sensors , so no it don’t works as Kinect.
