Newest RANGE 3D Scanner From Revopoint | Unboxing and Scans
I have the wonderful chance to be beta tester for Range 3D scanner, thank you Revopoint. :slightly_smiling_face:
The newest 3D scanner is mainly for large objects, you can scan with it furniture, full body scan using the new turning table, sculptures, statues, car parts or anything you can think of. It is made for big objects. (some objects might require spraying with 3Dscanning spray)
I personally use it to scan art: sculptures and statues, garden ornaments.
Because of infrared structured light it emits you can scan objects in full RGB colour :partying_face: :tada:
The Range scanner captures a enormous amount of data providing high quality point cloud witch will result in a very good 3D scan. No issues with tracking because of it’s big Field of view. Scanning with it in general is very fast, you can have a mesh in minutes.
Below are pictures with what you get in the package but also pictures to compare with Mini 3D scanner. You also got a picture with the 500mm turning table and the fancy remote control, Revopoint provided. I totally recommend this 3D scanner, i like it so much and it’s really amazing what you can scan with it. Mesh quality on big scans it’s just mindblowing. If you have any questions feel free to ask.
Range 3D scanner will launch soon on Kickstarter: Revopoint RANGE: Big Scans, Big Detail by Revopoint 3D — Kickstarter
This is my first scan with Revopoint Range and i’m very happy with the result.
Size: 36cm height and 17cm in the widest point.
3D scan of Abstract Statue Sandstone Resin Keep Silent
More 3D scans to come :slightly_smiling_face: :upside_down_face:
Impressive.
Can you scan an object that have small detail with MINI and RANGE to see how many difference there are between the two scanner?
Hi @Simos the MINI is 0.02mm the Range is actually 0.1mm so range has less details , you can’t compare the 2 scanners as that will be a question like what is better a Microscope or Telescope .
You can’t scan object at the size with MINI , neither Range is replacement for MINI or POP2, they still have higher accuracy .
Another scan with Range 3Dscanner. A lion statue mesuring 32 x 25.5 x 53.5 cm 8.75 kg
I used the new 50cm turning table to scan this.
Looking great @Cristi
Thank you. The scanner is very fast and accurate, I should try scanning some people.
Looking forward to see it!
I am about to scan some modern 2m sofa tonight , very flat areas , wondering if I can keep tracking on it without markers .
Greek goddess flower pot scanned with Revopoint Range.
Scan settings: mesh level 7, zero denoise.
Size of model: 33x23x20cm.
Garden ornament measuring 36 x 55 cm scanned with the new Revopoint RANGE 3D scanner. The affordable, big object scanning Revopoint RANGE 3D scanner is NOW LIVE on Kickstarter via this link: http://bit.ly/3YbCIsK
My wife likes squirrels, so I’ve bought her a squirrel statue that looks very realistic.
I’ve scanned it to resize it and fill the garden with squirrels as a surprise.
Size of model: 27x27x15cm
The model was scanned with Revopoint Range.
