Hello,
Is there anyone or any organization (FABLAB, school…) in the Montreal area that has a REVOPOINT MINI and would allow me to perform a test on a specific sample that I have? I am thinking to purchase one but I am really not sure that it will work for my specific project (scan a metallic powder layer (non-reflective) and capture the surface topology in single frame mode). I tried with the POP and the results were not accurate enough.
Thank you
Hi, I do not recommend to use a single frame scanning , not for POP2 or MINI , the devices are not created for single frame scanning of any surfaces , as you going to result with lots of noises doing so, doing single frame you capturing only 2 dimensional object and the rest that is missed is generated virtually and not accurate . Measuring distance point accuracy with a single frame is completely different thing for a different purpose where the object 3D dimension not really matters but the distance between 2 single points .
There are people that confusing the hell out of it .
There is not a single frame scanning data available as single frame is not enough for a fusion to take process in Revo Scan, and scanning 5 -10 frames of the same surface at the same time without movement is not a single frame scanning , it is overlapping of frames resulting in bad fusing and bad accuracy .
You can scan with MINI a layer of dust , it can pick well a layer of 3D scanning spray since it has not only better accuracy but also 80% higher pitch point resolution than POP2 .
The smallest detail on a volume surface I was able to capture is s human finger print at 10cm distance from the device .
Upload a close up picture and I will tell you if you can scan it or not and how much details you can capture with MINI .
Thank you for the response.
In my setup, the sample to be scanned is fixed, and I need to perform the measurement on a large number of samples hence my idea of using the single frame mode. I could fit the scanner on a motorized stage to create the needed movements and reduce the number of measurements to be performed.
“The smallest detail on a volume surface I was able to capture is s human fingerprint at 10cm distance from the device .” That’s impressive, it should be more than enough to detect the artifacts I am analyzing (±100µm height deviation)
Attached is an example of a powder layer (10cm*10cm) to be analyzed.
Thank you
So far I detected height layer deviation of 3µm what is very small thanks to higher resolution of the pitch point distance , the software allows you to fuse at 0.02mm .
POP2 don’t have enough pitch point resolution to do that .
If you can create slightly movement at 10cm distance using MINI , you may capture the deviations without issue or noises .
I can try to recreate this for you to check out if it works .
What is the layer height of the powder from the surface ?
Below the measurement I did with a 3D Optical Profiler VR-5000 - KEYENCE. We can see the height profile varies between +54µm to -33µm according to the reference mid plane
“If you can create slightly movement at 10cm distance using MINI” regarding the movement to create, what would you recommand: vertical displacement, tilt, pan ?
Thank you
I would recommend horizontal movement for best results at slightly angle, but I need to run a test first to find the best angle , as not all positions can capture the finest differences and each surface need to be tested before .
I will run some tests tonight and post the results on various height of the layers .
But from the picture your posted , it may have no issue to capture the details , but there are also rules , what color is the material and the proper gain setting regarding the material , you may also lose some tracking if there are no variations detected . MINI is visual scanner so it relays on variations of the surface for proper scanning .
Also very high contrast in color can affect the surface results where darker surface may be higher than light surface due the gain variations . So if your scanned sample has one color the results are the best . And of course reflections are your enemy as it produces false positives .
I will catch up with you later when I am back home around 3 hours from now .
Thank you for the insightful comment.
I can add a small mechanism to move the scanner horizontally and include a small angle during the displacement.
The color of the material is grey as seen in my previous comment.
I may add some markers in the surrounding area to help with the tracking.
The area of interest is the powder (non-reflective). It is surrounded by an aluminum substrate (highly reflective as seen in the picture). With the POP, I used the “Dark” mode and it could easily focus on the powder and neglect the surrounding aluminum substrate (I don’t know if the MINI will work the same).
Thank you
that is a very good approach, I made some tests , but need more time to be precise , I need to find out if the 3 microns layer is real or optical illusion created by the scanner due to color contrast , I am sure 7.5 microns can be scanned for sure but if anything below that I need to make more tests to be 100% sure if the 3 microns are optical side effect or not.
From your picture it seems like you will have no big problem scanning the powder differences but how physically accurate they are , only you can find out .
So give me little more time on that .
Thank you for your time, the 7.5µm sensitivity is already great.
