Revopoint MetroX Laser Mode Scan (Full Video, NO CUTS)
Watch a real-time laser scan with the Revopoint MetroX 3D scanner.
Get 33% off on Kickstarter now: Revopoint MetroX 3D Scanner
PS: Our software is continuously improving, and once the GPU acceleration is enabled, the scanning frame rate will be significantly faster.
Can you already disclose some informations on GPU acceleration, like for which GPUs will it be available (Nvidia, AMD, Intel) from which generation on and so on. If you cannot disclose such informations know, can you please tell when such informations will be available? TIA!
Hello ivan, our software is still evolving, currently, a GPU is not required to run MetroX; it is optional.
As the software progresses, there may be changes in the future. Please continue to stay updated with us.
Will the GPU be supported before the end of the Kickstarter campaign?
Actually (from the video) it looks slow to capture data.
I have a Quadro A4500 in my laptop, will this be supported in the software?
Yes, it can. For the GPU, our recommended configuration is: GPU (optional): NVIDIA GeForce RTX 3050 (8 GB). Your computer’s configuration exceeds this parameter, which is no issue for the MetroX.
