Hi @djsteffon
Sadly this is not the proper way to scan your objects when using this options that was available in v4 .
It delivered too many overlapped frames for no reason .
Once the coding is improved , it will be probably added back to latest version in the future .
What I do to get it works is using Android app to have fully control over the turntable like no other … works great even with Photogrammetry and also will be very usable with the up timing “MIRACO” 3D scanner. You can program it anyways you want with that app .
You can download it here
