Could you all possibly put back the options popup for the dual axis turntable (like the Revo Scan 4 software) to have the options of doing 5 different passes with a different selectable degrees. I need the ability to do one pass, stop, move to the next angle, do one rotation etc… Seems this is missing with Revo scan 5 or am I missing something? Kind of a bummer to have to use the scan 4 software to do the automated passes and then have to export it to be worked on. I wish Revo Scan 5 had the exact turntable options as Revo scan 4.
Hi @djsteffon
Sadly this is not the proper way to scan your objects when using this options that was available in v4 .
It delivered too many overlapped frames for no reason .
Once the coding is improved , it will be probably added back to latest version in the future .
What I do to get it works is using Android app to have fully control over the turntable like no other … works great even with Photogrammetry and also will be very usable with the up timing “MIRACO” 3D scanner. You can program it anyways you want with that app .
You can download it here
Tried the phone app (not official) and would not work on my phone. Could not connect. Some error about low power bluetooth.
The revo android app works but the datt app just gives me “not connected to a bluetooth low energy device” error.
This means your location is not ON , as that is required to run it for some reason .And nothing to do with tracking location , but it will not connect without .It need location to find nearby Bluetooth devices .
Location was on. turned it off and the ttable did not appear in list. turned back on and datt sees it but when i select it, it still does not connect.
xiaomi note 7
Please go to the DATT thread and ask Johnathan about the connection issues since it is not official app … maybe someone else can help you out more … as my knowledge ending here regarding it .
