Programming Dual-Axis Turn Table
I can’t seem to find settings in RevoScan5 to program the rotations of the turn table at different x-axis angles. Was that feature removed? If so, why? I found these settings in an older version:
Exactly…This is an important feature that needs to be included. I bought this turntable solely to have this feature.
Looks like removed
Indeed it would be fine to integrate the turntable to revoscan more smoothely. Best would be if the scsnner knew how the TT rotates und could predict its movement. I know this would make necesary some kind of calibration to get the starting position, but this eould be great.
Hi @wmcnally
Welcome to our forum. :raised_hands:
Thank you for your suggestion. I will provide this feedback to our dev team.
Hi @wmcnally
This feature is not supported in Revo Scan5 and will be considered for addition in subsequent releases.
I found this also. There is open source program on GitHub. I’ve had someone make a html code which works nicely, going to get it made into a windows exe program as well
I had it made with multiple lines, so rotate 360°, tilt however many degrees, rotate again. Have added in a pause option as well so it can be use for photography as well.
If you have Android phone , here is full android app with all possible combinations for the dual axis … including photogrammetry.
do you have link?
I suppose it is this one
Both controllers works great !
maybe i’m stupid but i didn’t get this one working. for some reason my pc won’t connect via bluetooth to the dualaxis. it’s odd because even in revoscan i have connection issues… it will instantly loose connection after connecting only way so far is to control it by the ios app. i haope they will add a step by step turn function as well soon. seems like i need to get an old android phone, needs one anyways for my gps ntrip services :smiley:
Remember the dual axis turntable require location to be able to connect on Android … working great with my Android phone
Hi, I recently bought a pop 3 together with the Dual Axis turntable and I was wondering when the possibility of programming in revoscan will be reinstated.
Hello, are you referring to programming for automatic control of scanning using the dual-axis rotary table?
Buongiorno yes correct.
More to this.
There are desktop scanners that we use at work to scan customers models.
They have a set scanning routine. Then you select parts of the model that did not scan well, and subsequent scans are done of that selected area.
We then flip the model to get the other side.
We scan mostly small objects like rings and gemstones.
If you could get the dual axis scanner to have a routine that marries up to your products you would get a lot more business.
The scanners that are your potential competition cost from $5000 to $50,000.
If you added this functionality you would change scanning, of small objects at least, from a scanner that requires an art form to get good scans to a tool that would be used in the jewellery industry.
Him any news if the function will be re-implemented in revo scan 6 or following versions?
Hi @HumArTrick
Right now there are no news regarding this topic
