Pop2 can now be recognized.
To connect to a PC, Type-C is directly connected to Note-PC.
In the past, we didn’t recognize Buffalo’s external SSDs, and the materials at that time were helpful.
Deleting Windows 11 junk files → Clean up the registry → Reinstall the USB driver → Delete all the peripherals that can be deleted → Run the current Windows update → Power the USB driver Change to uncontrolled settings
I did too much, so I don’t know what is the right answer, but it was good. I won’t update Windows for a while.
From now on, you can focus on 3D scanning. ( Also, I think there are a lot of problems, but I hope it can be solved like a game.)
Thank you for your reply.
Below is an excerpt from the Buffalo page.
For customers using external SSDs and portable HDDs, AMD Ryzen CPU support
Our target products use UASP (USB Connection SCSI Protocol) for USB transfer mode, but AMD’s Ryzen CPU does not work properly with UASP transfer, and our products recognize it. You may not be able to use it.
By using the USB transfer mode switching tool described below, you can avoid this problem by setting the firmware on the side of the product to run only in BOT (Bulk Dedicated Transport) mode. This product can be used normally with the CPU.
For individuals who have switched to USB transfer mode using this tool, the transfer speed of the product may decrease after switching.
