RANGE - Unboxing and Showcases
RS5 in marker mode, Pottery manual aluminum turntable with markers, Model with aesub
Setup
Pointcloud
RAW Remesh L7/1%
Smoothing 1x F20 C0.5
Smoothing 10x F20 C0.5
Such a great marker placement on the plate! How did you come up with it? would you mind sharing a photo of the plate/turntabel from straight above? I would like to copy the markers placements.
Sure here it is
I started with a spiral and conter spiral of ones
Then i go spinning around starting with a pattern of 1, 2, 3, then 1|1, 1|2, 1|3 , 1|4 … and then I adapt as i go trying to keep the clusters as clear and unique shapes as possible.
I also have the pattern on the side you can see it in this video
Ingenious! :clap:thank you!
USECASE
Dirty scan (RANGE+MINI) for quick reference to build a acrylic expositor base for a powertool, base resulted great on first try, no iterations needed and the process was faster than any old methods.
Workflow
Scan and basic cleanup: RS5.0.1
PC alignment (range and mini) registration and meshing: Cloud Compare
XYZ flat plane initial orientation: Windows builder - Settle tool
Mesh final ortographic orientation and mesh simplification: Meshmixer
Model Build using mesh as volume reference: Fusion 360
Newest Range scan
Subbuteo trophy
Head scanned with Range, body photogrametry scan, base fusion360 model. Software used, Revoscan, Meshmixer, Fusion360, Meshinspector
Subbuteo original 00 scale resin test prints
Handpainted and reference
Nice looking!:clap: just wondering: why didn’t you use Range for the body scan , too?
Never had access to the model in the game clothes, i used another user stock photogrametry for the body then modified it to fit the general body of my model from photo reference.
Initially my scan was only of a shell of the face, later i did a scan of the hair on a nother session to use as reference and sculped the model as needed
Nice work on this one , did you scanned the new body ?
Body is photogrammetry, only head is range
Done
