Good morning to all people onto the forum, Finally I have receved the range scanner… wery proud to have win the showcase contest… here some photo of the unpackaging and the series of scan I have bought from revopoint… have a nice week end to all…
the last project have only the first Icon blu… I try to tap but nothing appens… what do you think it’s appen…
I have also made some test… for the part that is not scanned like vertical wall or certain part inside the scan… how do you solve the problem because I try to full the hole but revo put black area inside the scan
If you prefer to scan using Revo Scan on your phone and edit on your computer, there are two easy ways to move the files to your computer: 1) Export your PLY/OBJ/STL files to the cloud; 2) Save your PLY/OBJ/STL files to a flash drive connected to your USB port and move the flash drive.
I think very well try… I must learn to scan in one time… for that I made 4-5 scan and after join into studio…
but when it’s 3d without rotating table is very difficolt…
No wonder you can scan when the mountain cover the radiation , plus you are in Europe so the dusk and dawn are very long compared to only 20 min here in NYC
@GMGB I use USB stick and scan the model direct to it , then after I plug it to my computer and mesh it for maximum quality , phone don’t give you that level of details , you need to process the fused ply files and mesh it on computer using Revo Studio or Mesh mixer or CLoud Compare
That is the fastest way to move your files around .
P.S please post your showcase scans in one thread for now until KS Campaign ends .
Do not post your scans under other’s users showcase threads .
Another test of range that I made yesterday evening at home… without rotary box…
with my galaxy note 10 plus and range scanner
after sent with whatsup to my whatsup download into the PC and making the joint of all the scan…
with revostudio…
Another test for a statue…
the proble was the High of the model
with range I was able to do but I must made 8-9 different scan and after join toghether…
Looking good @GMGB
If you have some errors you can try to fix it with overlapped points tool in Revo Studio before merging to remove the lose points .
Also Cloud Compare can clean it nicely with one click .
Always clean the fused point clouds from errors before merging , it would be easier than after merging .
However I know the scanning task of this statue was not an easy job .
Note:
Please keep your scan results in the same original thread until the end of the Range Campaign.
I moved this one here already .
