Jta
1
The Metro X scanner is unable to scan in laser mode, this option does not appear in the drop down
menu and it starts in full Field.
The camera recognizes the markers and the green bar move, however no scan is done after pressing start.
I have made several scans and the scanner is a working tool, this is the first time this happened.
I think this is a software issue since the scanner works in laser mode in Revo Scan MetroX.
Specs:
AMD Ryzen 9 7900X
RAM 64gb
GForce RTX 4070 SUPER
PUTV
2
Hi @Jta
Please click here to use the laser mode , a new menu will be available after on the right
I see your menu is still set to Full Field and not Laser mode , the laser mode is activated once the scanner sees the markers .
If still nothing happening , please reinstall the software and calibrate your scanner .
You can also contact customer@revopoint3d.com for technical assistance in case nothing above worked .
You suppose to have Laser mode here not Full Field
Jta
3
The answer to that statement is in the first picture. That option is not there, that is the issue.
Already solved it by reinstaling.
Thank you nevertheless
