Pop3 Vs miracolo plus
Dear all, I would like a 3d laser scanner and I would compare Pop3 and miracopro plus. I would ask you some comparison and your opinion betwenne the models.
Many thanks
Hi
Here you go, check the following link to the page where you can choose which Revopoint 3d scanners you want to compare , side by side .
Notice, none of available Revopoint 3D scanners is a laser 3d scanner. Mini-Series are structured blue light 3D scanners, Miraco and POP3 are IR (infrared) light 3D scanners.
Please also notice when starting a thread that this forum has different sections for better overview.
Hi @dset and welcome to the forum .
There is truly not comparison between the 2 models because both are totally different , POP3 Plus is used to scan small to medium size objects and requires phone, tablet , laptop or computer to operate .
MIRACO Pro is standalone so you can scan objects directly , without the need to connect to any other devices for scanning . It can scan small medium and big objects so definitely 2 times better than POP3 Plus , if you have the budged go with MIRACO PRO … more versatile , it all depends what kind of objects you want to scan with .
