I own a range and pop3 both with the phone handheld acesory. Would there be any ugrade if i switch to miraco? Or better keep the money and use pop3 + range?
Hi @rwijnhov for scanning wise not really as you already have the range in house and the accuracy is particularly the same .
I still prefer Range for many tasks
Miraco is more when you go outdoors easy to have one scanner to do the all job … more all in one luxury experiences .
HI
You can compare them here:
IMO: if you don´t need higher accuracy, switching between the scanner and using you phone you can stick to your scanners. Depending what you scan I would consider metroX as an upgrade, which on the other side is pc/laptop bound.
