Today I tried to scan a piece of 17 mm thick wood board standing upright on the turn table and experiment with different kinds of features placed around it. I did not get any tracking loss but the accuracy of the model is not great, the top of the board is thicker than the bottom by about 0.17 mm in the model. I have the feeling that this is more due to frame stitching error in the fusion process than the accuracy of the scanner itself because I did not see this kind of error when scanning a cylinder of the same height and surrounded by the same set of features ( small square blocks ).
Not sure if this indicates anything but upon examining the raw data and the key frame views of the scan, it is found that the starting and ending frames do not meet in the raw data view but perfectly in the key frame view. Is that something normal ?
