As topic say. I’m choosing options either on my PC or my iphone but neither software on PC nor iphone app export scans to STL or OBJ
Are the files not being created at all? Do you get a failure message?
STL will not even be an option for a Point Cloud (it doesn’t support them), but I have no problem exporting mesh files to STL or OBJ.
In which folder are you exporting files (and creating the project folders )? It is possible that, if you are using the default, it’s pointing to a sub-folder under the Program Files folder and you do not have access unless you run in Administrator mode.
