I purchased a POP 2 scanner in June 2022. Here is a compilation of my best work so far.
84 Magna 500 Clutch Slave Cylinder
This was scanned with AESUB blue spray. I was not able to get all of the inside of the cylinder, so I used Revo Studio to auto fill the hole. Much of what looks like imperfections around the outside of the cylinder is actually leftover gasket material.
Original Part and 3D print of Scan. The scan was not oriented perfectly in the slicer, causing the surface finish on top.
Valve Cover
This was before I had scan spray. The other half of this cover does not have many unique features, so I was running into tracking issues since I was not using markers.
Saturn 5-speed transmission
Scanned without spray, the part was dirty enough to scan well without it. I could probably fill in some of those holes with additional detail scans.
84 Magna Side Cover
Got away with not using markers by keeping the corners or the tabs in the frame.
81 Suzuki GN400 Motor
My most involved scan so far. The result presented here is a merge of 5+ scans. Need a few more scans to fill in the remaining holes.
Exploded Piston
This came out of a 2-stroke golf cart. I did this in “fast scan” mode instead of high accuracy. This is a combination of 3 scans and my alignment is not perfect.
