Is there anyone in the Revopoint community with the new POP3 and access to a couple small animal bones who can showcase a few scans? Thus far, all of the examples I’ve seen are scans of models, sculptures, the usual stuff.
I have over a dozen horse neck bones that need to be scanned for a research publication but the funding is out of my pocket so you can see why I’d like to view results before making a purchase. Details and accurate RGB are a must. Any takers? Thank you!!
Thank you! I am not interested in printing them, just getting good scans with realistic color. Did you do these in one scan or several point clouds that you merged? If the latter, can you export the merged file as an .obj along with the texture file? I discovered this can’t be done using the Mini.
Please bear with me, I am a newbie at this. I understand most of the basic concepts but have a lot to learn!
This is an example of how I need the bone color to be as true as possible. This was scanned with a very high-end Artec scanner and I understand not to expect the same quality but am hoping the POP 3 might do good enough for my research. WhoZat_C7 - 3D model by bonelady [ebb7519] - Sketchfab.
Hi Jonathan, I have Google Drive or We Transfer (info@equus-soma.com). This is a newbie question, but why are the models in some of the screen shots blue? I don’t see this when scanning with the Mini. Also, how many total frames do you shoot for in a scan? I’ve read different numbers. Thanks!!!
If you click this icon you get the fused point cloud or mesh without colour, the blue makes it easier to see if you have a clean mesh or point cloud without the colour
Hey, thanks so much for your reply. Would you mind elaborating on how many scans this took? Did you have to fuse separate point clouds? and how does the texture look, true to life?
What other bones have you scanned? Cheers, Pamela!
