I have a vehicle interior to scan. With the vehicle door open it blocks a fair amount of the area that the tracker cameras can see.
Can the tracker be placed at an angle, or vertical so the cameras can see the scanner head?
Hi @Kenjhall
You can put the Tracker in any position you want up or down regardless as long it can see the marker cage of the scanner.
Tracker only needs to see marker points on the hand piece at a time so yeah. Just orient it as you need to, worst case tracking fails and you need correct the orientation a bit
