I’ve been testing the Range 2 in the UK, lights off, indoors, no artificial lights and getting pretty good results. So pretty low ambient light conditions.
But I’ve got a project coming up where the ambient light levels are much higher and some of the items to scan are outdoors. Do I just adjust the exposure for this or is there more I will need to do (i.e. scan in the early morning)
You can’t scan outdoors if the sun is up , you need a very cloudy day , or 2 hours before sunrise or after sunset .
The indoor lighting can be whatever as long the lighting is not direct via the window .
Sun light include infrared light, and I infrared is used by Range 2 to scan your objects .
Artificial LED lighting do not affect scanning with Range 2 .
Always use Auto exposure for Depth camera .
But for RGB you need to set it manually , White Balance then Exposure .
