I’m having difficulties with my range. I’m scanning smaller parts like a patinate door handle from a carrier. Gilded objects and clock parts as a test.
I tried to do a large light up sign that has had difficulties.
So, there’s some learning curve or I’m starting to feel like my instrument is cursed.
Yes it is , your objects still need to have tracking features , Range was made to scan big objects , at least 26/11inches and up at the distance of 30cm .
It can scan smaller objects but the accuracy will be lower and in case your object do not have much of features you need to use markers or add additional elements .
Range is the most simple scanning solution scanner but you still need to keep the rules while scanning and practice .
Start from a place of simplicity to complexity - like learning to drive, you don’t hop straight onto the motorway!
I have 15 year experience scanning and reverse engineering, it takes time, patience and experimentation. Try scanning matt objects like cushions or clothing on a clothes hook with the range to start with.
This example is pushing the Range quite a bit, lots of featureless flat surfaces going from one extreme to another in surface reflectivity from gloss white to matt black. It takes practice.
P.S I created your own individual thread here for showcasing your Range scans , since the other was personal thread of @JonHimself
Feel free to post your scans , ideas, questions , trouble shooting here …
