Just some random Scan’s with the Miraco.
Still not perfect, but I progress. ![]()
Very good scans @GerritCorsmeyer as for the begining of using it , not bad at all !
Nice one. That’s a very good start for sure.
Here is another one I could recover from my messed up Projects.
First one is with Miraco RGB Camera, second one is a reapplied Texture from 12MP Photographs.
I think I am not a big fan of the build in RGB Camera.
Happy Christmas all of you ![]()
Mery Christmas
to you and yours !
Lovely scans! Merry Christmas all ![]()
Hi,
Very impressive.
How did you scan bottom of those animals?
I tried with turntable. But I couldn’t get enough scanning of under surface.
If you can give me any tip, Appreciate.
@zinkenhopp
Just turn on the Base Removal, make the first scan in a standing position in feature mode. Then press pause on the scanner and try to lay down the figure. Try to match a already scanned part, and Miraco should match it.
Sometimes I need two seperate scans, and merge them together.
Gerrit
Thank you! good tip.
