Hello. I am using the revo mini to scan some small (38 x 12 mm) solid items. The problem I have is that they scan but have no bottom and look like a hollow face mask. I have 7 items and only 1 has scanned properly. Any help would be appreciated.
Select “fill holes” when you mesh the scan.
You will need to take the meshing off “auto” to do this. After fusing, click the arrow next to the Mesh icon.
Maybe better if you export the meshed and close the holes in Revo Studio to avoid round surfaces on the bottom .
Revo Scan usually use tangent space for closing holes what is organic .
Using flat/ panel will create flat bottoms as you need.
