MetroY Pro + Wi-Fi Repeater for Long Distance
Tutorial: Using Revopoint Metro Y Pro at Long Distance (20-30m) via GL.iNet Wireless Bridge
If you need to use your scanner in a workshop or large area about 20-30 meters away from your main workstation, you have likely encountered connection drops or a weak Wi-Fi signal.
While the official recommendation is to keep the scanner and PC in the same room for stability, I have developed a robust “bridge” solution using a travel router. This setup has allowed me to perform continuous scans for over 1-2 hours, handling sessions of up to 7GB of data without a single interruption.
:warning: Disclaimer: This is a community-developed workaround and is not officially supported by Revopoint. Use it at your own risk, though it has proven perfectly stable in my professional environment.
:hammer_and_wrench: Hardware & Requirements
  • Scanner: Revopoint Metro Y Pro.
  • Router: GL.iNet GL-MT3000 (Beryl AX).
  • Cable: 30m Ethernet cable.
  • Software: Revo Metro (Tested on v5.8.5).
:satellite_antenna: Connection Layout
PC (Office) <--- [Ethernet Cable] ---> GL.iNet Router (Workshop) <--- [Wi-Fi] ---> Metro Y Pro (Workshop).
:gear: Step-by-Step Configuration
1. Physical Connection (LAN Port)
  • Place the GL.iNet router near the scanner in the workshop.
  • Connect the 30m Ethernet cable from your PC’s network card to the LAN port of the GL.iNet router (avoid the WAN port to prevent firewall issues).
2. Enable the 5GHz Channel 149 (Region Settings)
  • Log into the GL.iNet admin panel.
  • The Metro Y SSID is often invisible on standard European/local channels. Change the router Region to “US”.
  • This enables Channel 149 on the 5GHz band, allowing the router to see and connect to the scanner’s Wi-Fi.
3. Repeater Mode & Stability Tweaks
  • Set the router to Repeater Mode and connect to the Metro Y Wi-Fi.
  • In the Multi-WAN settings, set the Repeater as Priority #1.
  • Crucial: Go to the repeater settings and disable “Enable Interface Status Track”. This prevents the router from disconnecting when it realizes the scanner’s Wi-Fi doesn’t provide internet access.
4. Static IP & DMZ (Essential for Software Discovery)
For the Revo Metro software to “find” the scanner through the router, the traffic must be directed to your PC:
  • Static IP: Ensure your PC has a fixed IP address within the router’s range.
  • DMZ: Instead of opening individual ports, go to the DMZ section in the router settings and activate it for your PC’s IP address. This ensures all communication from the scanner reaches the Revo Metro software without being blocked.
:white_check_mark: Final Result
Once configured, open Revo Metro. The software will detect the Metro Y Pro immediately as if it were locally connected. You can now enjoy the full power of your office workstation while scanning large parts remotely in the workshop.
This setup effectively turns your travel router into a high-gain remote antenna, overcoming the limitations of standard PC Wi-Fi cards over long distances.
I got this working, but not able to mirror to phone. How did you screen mirror or remote desktop in to see your scan progress away from your main workstation?
Hi @Rmneal
The phone and PC need to be connected to the scanner WiFi , then you need the Mirror app to be installed on your PC and Your Phone and start it on PC .
The mirror app don’t mirror PC screen , it only harvest the power of the PC .
If you use alternative ways I can’t help you much here as I did not tried it.
With this setup, connect your phone to the Wi-Fi network created by the repeater, not directly to the main router. The phone and the PC/scanner must be on the same network so RevoMirror/RevoScan can detect the device correctly.
Thanks PUTV & Gerard14! Got everything up and going. Figured it was something simple that I was overlooking…and it was! Was trying to connect the phone to the wrong network. Y’all are awesome!!
Glad to heard you figured it out !
How about just getting dedicated router and bridging remote router with VPN to main network? Does revopoint software needs some special ports/protocols or it’s just IP - IP comunication?
This way - distance between PC and scanner could be unlimited.
Hi @Prakaejas
You will need to test it by yourself in this case , everything is possible.
As long both the scanner, PC and Phone is on the same network with proper speed , you can archive unlimited range.
So far I know people use it at 25 meter distance without issue .
What I meant was: going somewhere with a prepared portable router, connecting wan port to remote location’s internet, make vpn connection to home PC LAN network and use mirror app to control scanner and remote PC. If scanner and mirror app communicates on basic tcp ip protocols, it should work, right?
I am waiting for pop4, can’t test it yet, just preparing ideas how not to be locked to the same location as PC.
Theoretically should works , but everything depends on the network speed , laser mode need everything you can get so no delays in data transfer , the other modes can work straight on your phone without need of mirror or other things .
Good day
Could you let me know what software your GL.iNet runs on, as I have one with v4.8.1 and it will not see my scanner’s Wi-Fi. Thanks
