Cannot calibrate MetroX
Hello,
I’m running 5.6.4 software, with firmware v2.1.81.20250303.
I’m trying to run the calibration, and I keep getting a "Failed to set camera parameters. Press OK to exit this calibration. Please reconnect your device and try again.
You click OK and it exits calibration mode.
Any ideas?
Hi @kennytent
I would like to ask if reconnecting and trying again still doesn’t work?
Please follow the troubleshooting steps in this article and try the suggested methods to see if they resolve the issue.
MetroX: I have a problem connecting the scanner (Error Messages)
The link worked perfectly, Thank you.
I also encountered a problem, I can’t calibrate the scanner, and I also can’t check the existing calibration from 04/17/2025. I rebooted the computer and scanner several times, turned off the power and reinstalled Revo Scan 5 MetroX. I tried to calibrate on a laptop, the calibration starts and runs, but at the moment of writing data to the scanner, the Revo Scan 5 MetroX program crashes
Hi @Berear
For technical assistance with calibration issues as there is nothing I can help you here with.
make sure you are connected to USB 3, and it shows on the home page next to MetroX Image after your connect it .
Technical assistance will help you out .
Did you try the instructions in post #2?
It worked perfectly for me.
