I’ve just fired up the MetroX having updated Revo Scan to 5.6.2 and was presented with a new firmware. It has some basic notes but is there anywhere which shows exactly what has been improved/fixed? Thanks
Nope. We don’t know for sure. There have been a couple of people say they have problems with it, but most reports are improvements. I wish they would include better notes and a rollback method.
Hello, this firmware upgrade enhances the stability of the scanner.
Should I assume we must calibrate after applying the firmware and software update? I’ve done the updates, but haven’t scanned anything yet.
You can first check the accuracy of the scanner, and if the software prompts you to calibrate, you can calibrate it.
Were is firmware update? I updated my software to 5.6.4 and i dont see handheld firmware.
Were is firmware i updated the software to 5.6.4 but cant find handheld firmware.
What handheld update you looking for ?
The firmware update was for MetroX in January .
If your MetroX have new firmware it will pop up after you start the software , make sure you connect MetroX first and run Revo Scan MetriX 5.6.4
If the firmware is up to date then not.
It is an automatic process.
